After using a Morse hole saw to cut some circles for a project I needed a quick and easy way to sand the edges and maintain the same size for each circle. The hole saw leaves a really rough cut.
The jig is a short board that fits into the track on my oscillating belt sander. The right end has a 1/2" dowel mounted that an arm roughly 3/4x3/4" can pivot on. Since the Morse hole saws use a 1/4" drill as a guide the circles have a 1/4" hole in the middle. About mid way on the arm there is a 1/4" dowel that I can put the circle onto.
Using my right hand to keep the circle from spinning, I slowly push the left end of the arm until I can slip a removable dowel pin into the board. This dowel pin is set to hold the arm at the exact location to sand the circle to the desired diameter. After the pin is set in place I can rotate the circle until it is sanded all the way around without any flat spots. I can drill additional holes in the future for different diameter circles.
I know there are better and more sophisticated circle cutting and sanding jigs out there but this took me about 45 minutes to build including glue up and it more than doubled the speed in which I can make circles and greatly enhanced the accuracy in which I can reproduce them.
