1 - 3 of 3 Posts
a right triangle
The acute angles are 45 degrees, the right or square angle is 90 degrees.
The best, easiest, fastest and safest way is to use a sled for your table saw.
http://www.woodworkingtalk.com/f27/table-saw-sled-build-49218/
The second best way is to set your miter gauge to 45 degree and cut the angles that way. You should have an extended fence for support.
Start with a 12" wide board and make the diagonals using the miter gauge, NOT the rip fence of course.
there are 2 - 12" sides and the long side, the hypotenuse, will be 16.9"
Other methods would include a sliding miter saw OR a radial arm saw set to 45 degrees.
Reactions: chris7981
1 - 3 of 3 Posts
