1 - 16 of 16 Posts
I am making signs from 2x6 treated SYP for our Boy Scout camp. Routing them is one thing but painting the letters is tedious & very time-consuming. As a result I put the project off too much.
My question. Is there a film, spray-on or otherwise, that I could apply to the painted sign boards that I could then rout through, paint the letters, and peel off without lifting the latex paint off of the boards.
I've tried blue painters' tape & self-stick transfer paper. They ball up in the router bit and I get a less than good job.
Thanks for any tips.
Forester
John
Forester
I take it the letters are recessed??
Actually wouldn't make much difference. I've used Elmers Craft spray adhesive and just regular printer paper and routed through that. Results were OK, not spectacular. I did pick up one method I have yet to try. Krylon clear acrylic spray, available at Walmart in the paint department. Spray the sign first, route then spray paint the letters with the desired color. Then hit the sign with a belt sander to take the acrylic and overspray both off. The acrylic prevents the paint from soaking into the wood. Like I said, I haven't tried that yet but it sure sounds like a winner. I have precoated a sign with poly and routed through it then spray painted and cleaned up the overspray with mineral spirits and a cloth. Turned out OK but wasn't a whole lot of fun.. This is it
Reactions: Forester01
I second TVMAN. If you have a planer, I would paint the letters and then a real light pass through the planer will clean the paint right off the main sign part. If you don't have a planer, belt sander or maybe even a palm sander would do it...
Banned
I grew up around a guy that made tons of those signs. freehand lettering with the router and contact paper just like I explained. he use to set up at the malls with a trailer and crank out several hundred if not more signs using that technique. I know it works.:thumbsup:
Super Moderator
When I make routed signs, I use black spray paint for the letters then run it through the planer without any problems. The paint film is so thin it doesn't affect the blades at all. One or two passes taking off just a shaving leaves the letters nice and crisp looking. Then I'll usually use some aerosol clear wood finish to seal everything. If you're using the signs outside, I would skip the clear coat.
Mike Hawkins;)
Forest Trails
Thanks nblumert for the tip on sanding sealer. Did you use templates, a pantograph, or something else for the lettering. If you used templates I thought you might know where to find routing templates for letters 1" or less in height. Thanks.
i didnt use templates or a pantograph, this sign was done on a cnc machine. Here is a picture of one i did this year for the same kid. This one was freehand with the router.
Nick
Table Wood Font Plywood Furniture
Forester
Try OraMask 813. It stays put and works very well.:thumbsup:
1 - 16 of 16 Posts
