Hello all,
When I finish a project with tung oil in the winter (which I'm planning to move away from), I bring it inside to allow it to dry in a warmer and consistent environment. However, as I'm sure you know, tung oil has a strong smell until it dries. The smell usually fades enough in a day to not be noticeable but it made my girlfriend ask "why don't they make it scented?". My initial thoughts were that I don't know what chemicals are used to scent candles (or chemistry behind wood finishes) so maybe it would interfere with the color or bond. I figured I could make some rosemary tung oil (fill a little jar with rosemary and then fill it with tung oil then wait) and test it out. Before I go through this effort and wait a whole month though, I thought I'd check with you all to see if there is a good reason I've never heard of scented wood finish. The biggest con might just be that the scent will fade quickly meaning only the maker and their household will potentially see the benefit but I'm a maker so that would be good enough for me to make my own oils with simple scents like rosemary, thyme, and creosote.
Thanks,
Thanks,
