10" circular saw blade? .... unlikely
A 10" blade would be very unusual on a circular saw, but Milwaukee makes one for sure. The number and type of teeth should be written on the blade. It may be something like 28 T, 40 T or 60T... Is the blade made for ripping or general purpose?
http://www.ebay.com/itm/48-40-4170-...408?pt=LH_DefaultDomain_0&hash=item46071522d8
The blade above is a 10 1/4" diameter. This may not fit on a standard table saw which may be limited to 10" blades only. The extra 1/8" measured on the radius, could rub on the mechanism at some point, so be very careful. :yes:
Some woodworkers routinely use the smaller 7 1/4" blades because they are so much cheaper, and will still cut 3/4" and 1" thick material on the table saw. Wood is still wood and the blade don't care where it's being used....circ saw or table saw. The only factor would be the RPMs may be greater on a circ saw, but it will still work OK on the table saw.
Can you post a photo of the blade or package?
