I have a Hitachi 10" sliding miter saw spinning a Freud 80 tooth finish blade. This has been working well for quite a while but recently I've encountered a couple problems. If working from the left side of the blade (which I normally do since I'm right handed), I've started to get tearout, burning, and even gouging by the trailing edge of the blade. If I switch sides and work from the right of the blade, I get very little of this.
Does this sound like a saw alignment problem or a failing blade problem? I've removed, cleaned, and reset the blade, but nothing changes. It's not a new blade, but I've certainly not put it through as much use as any pro would. And there is no apparent tooth damage.
I contacted Hitachi about alignment procedures and they just sent me a link to find a repair facility. :thumbdown:
Any ideas or thoughts would be appreciated.
Thanks,
Wally
Thanks,
Wally
