Built a play table for my son. Finished the top of the table with glaze coat epoxy. On day two of the epoxy drying and curing my wife placed a towel over the table and applied pressure leaving a hand print impression. I tried lightly sanding the area with 800 grit and polishing but the haziness is still there when the light hits it right. Can I repair this without having to strip and re epoxy? If I put more epoxy over the area with the haziness will the haziness show through or will the epoxy just fill in the void with a clear finish? Thanks for the help in advance
A fresh top coat should restore an even sheen---after fine sanding of the entire top---
without a picture, it would be difficult to guess if the cloudy area will clear up--
I had something similar with a vanity top. I ended up sanding at 150 grit across the whole thing, then flood-coating the entire top. Granted I tinted mine with gray, somewhere between translucent and opaque, and you cant see any of the sanding marks under the top layer.
Assuming that the epoxy is now completely cured, you have 2 options:
A) Sand and polish the entire table top, working your way up to a 3000 grit sandpaper before following with a polishing compound, to bring back a perfect gloss sheen
2) Sand the entire top with some 320 grit paper and pour a new layer of epoxy, but this time dont let anybody touch it
A gives better results, 2 is less work and will still give acceptable results
Super Moderator
Retired Craftsman
it's called a keepsake !!
put your hand on the impression and trace it with a Sharpie marker.
then, put your son's hand inside the drawing and trace his hand.
problem solved
