Hello all. Well, I bought a used Ryobi miter saw off of Craigslist. Paid $60. It had a relatively new blade, and looked to be in good shape. I was happy with the purchase as I made about 2 dozen cuts before it had a problem or two (simultaneously). The brake stopped working, and the blade takes a minute to start spinning after compressing the trigger, and it does not have much "umph" to it. Everything was going fine until I was cutting into a 2x4 and the blade just stopped. Then all the problems- brake failed, and weak power- began. I had it plugged into a power strip that was attached to an extension cord which I worry may have been the cause. I plugged it into a regular extension cord (the usual way I do it) but the problem did not go away.
My plan is to check the brushes and make sure the blade is tight. I am actually excited because I will get to learn about how to fix a saw. If it was a new saw I think I would be pretty stressed but since I didn't pay much and I hope all it needs to routine maintenance, I am viewing it as a happy accident.
The Nut in the Cellar
What model is the saw? From your description, it sounds like a loose blade nut or a missing washer. Parts for old Ryobi tools can be hard to find. There is one in my town that is knowledgeable and pretty well stocked, but can order almost anything.
it sounds like it may be in the switch. when the blade stopped, did the motor stop also, or just the blade?
Thank you all for your help. I started troubleshooting this morning, and first thing I did was examine the blade bolt. I made the blade tight and that seemed to have fixed the problem. Still have to cut something but I think it's better. Glad it was a cheap fix, haha. I was thinking I would have to replace the brushes (still pretty cheap).
Again, I really appreciate you all's kind help.
TimPa, I believe the motor stopped as well when the blade stopped.
Many power tools are ruined by using too small of extension cord. I hope that’s not your case.
FWIW, I have a Ryobi TS and Ryobi only had one wrench for changing the blade. Try http://www.ereplacementparts.com for the needed parts. They had a supply of both wrenches in stock.
This is a good place to find parts that are not available from the factory.
FWIW, I have a Ryobi TS and Ryobi only had one wrench for changing the blade...
Luckily I had the multi-tool (phillips-head screwdriver and alan wrench in-one) that came with the saw. Not sure if it was an unusual size but sounds like it might have been so i was lucky to have the tool.
