Not that I can think of.Any reason this is a bad idea?
See post #17 for how you can center the general bushings. It's about centering the base plate, after centering the plate you can change to the bushing you will actually be using.It's a general bushing set and it did not come with any instructions.
Please be specific why you don't like bushings, you are a far more accomplished woodworker than I am, would like to hear your experience with them. For me they've been great, often for things like oval cat holes that don't need precision, but also stuff like dovetails and experiments with inlays.I hate them and use them as little as possible.
For your bowties, I would use a dado clean out bit.
True. My bit collection is currently pretty small though.See post #17 for how you can center the general bushings. It's about centering the base plate, after centering the plate you can change to the bushing you will actually be using.
I don’t like the the figuring that goes with it. Seems the offset is not always the same. When I make a template I find it much easier and more accurate to cut it exactly to the size and use a bearing bit. I know there are cases you can’t do that, but not many. Particularly mortises I can’t see a guide bushing there at all.Please be specific why you don't like bushings, you are a far more accomplished woodworker than I am, would like to hear your experience with them. For me they've been great, often for things like oval cat holes that don't need precision, but also stuff like dovetails and experiments with inlays.
Re bearing bits, the cutting diameter limits how tight a corner you can make. After routing you hand chisel the corners?
True, but the benefit to using a cone is that you can leave the base plate screws just a touch loose, then as you lower the bit into the bushing it will nudge it over to perfectly centered.A 1/4" drill bit will work for centering too, as long as it fits the collet well.
