MDF is pretty straight.
I looked at home depots site and the guide you used looks rigid enough. If the blade was sharp on the saw you shouldn't have had to put enough pressure on the guide to bend it. The bottom of the saw and perhaps the guide may also need some wax.Looking for someone who has a method to rip a 8' sheet of plywood. I used my Empire ripping fence and it bowed in the middle. 1/4" off now. Any recommendation of straight edge that can span 96" without bowing. Bora and Kreg both have options. Finding a straight piece of wood seems to be next to impossible. Recommendations? Clamping on each side of 8' seems like it would tend to bow. Any help would be appreciated. I cannot rip this would on my table saw. unlevel surfaces and no helper. Thank for the recommendation.
Here's a technique that I have used in the past. Get a 4x8 sheet of foam insulation that is a minimum of 1 in thick. and set it on the floor of the garage. Put your sheet of plywood on top of that. Then use a second sheet of plywood for the straight edge and use a circular saw for the cut. The saw will cut into the insulation, just make sure you set the blade so it doesn't hit the floor of the garage. I find that it makes cutting down a full 4x8 sheet when you're only one person a lot easier.Looking for someone who has a method to rip a 8' sheet of plywood. I used my Empire ripping fence and it bowed in the middle. 1/4" off now. Any recommendation of straight edge that can span 96" without bowing. Bora and Kreg both have options. Finding a straight piece of wood seems to be next to impossible. Recommendations? Clamping on each side of 8' seems like it would tend to bow. Any help would be appreciated. I cannot rip this would on my table saw. unlevel surfaces and no helper. Thank for the recommendation.
use 4 inch rip cutoff as your guide from now on?Looking for someone who has a method to rip a 8' sheet of plywood. I used my Empire ripping fence and it bowed in the middle. 1/4" off now. Any recommendation of straight edge that can span 96" without bowing. Bora and Kreg both have options. Finding a straight piece of wood seems to be next to impossible. Recommendations? Clamping on each side of 8' seems like it would tend to bow. Any help would be appreciated. I cannot rip this would on my table saw. unlevel surfaces and no helper. Thank for the recommendation.
10' piece of unistrutLooking for someone who has a method to rip a 8' sheet of plywood. I used my Empire ripping fence and it bowed in the middle. 1/4" off now. Any recommendation of straight edge that can span 96" without bowing. Bora and Kreg both have options. Finding a straight piece of wood seems to be next to impossible. Recommendations? Clamping on each side of 8' seems like it would tend to bow. Any help would be appreciated. I cannot rip this would on my table saw. unlevel surfaces and no helper. Thank for the recommendation.
The problem you are experiencing has to do with the span between your clamping points. I suggest you make your own saw guide using a piece of 1/8” Hardboard 8” wide and a strip of 3/8” plywood.Looking for someone who has a method to rip a 8' sheet of plywood. I used my Empire ripping fence and it bowed in the middle. 1/4" off now. Any recommendation of straight edge that can span 96" without bowing. Bora and Kreg both have options. Finding a straight piece of wood seems to be next to impossible. Recommendations? Clamping on each side of 8' seems like it would tend to bow. Any help would be appreciated. I cannot rip this would on my table saw. unlevel surfaces and no helper. Thank for the recommendation.
You must be kidding?It doesn’t have to be 96”; make it 54” long.
Also use it twice for your 96” sheet of plywood.The problem you are experiencing has to do with the span between your clamping points. I suggest you make your own saw guide using a piece of 1/8” Hardboard 8” wide and a strip of 3/8” plywood.
1) Take a 54” strip of 3/8” plywood with one straight edge.
2) Rip it 2” wide.
3) Glue the plywood to the top of the hardboard along one edge.
4) Glue 120 grit sandpaper to the bottom of the hardboard.
5) Run the circular saw along the edge of the plywood.
You now have a home made track saw 54” long that will not move when placed on top of a piece of plywood. Also, since it is fully secure along its entire length, you will not get any deflection along its length.
