Friend of mine has asked me to restore his front entry door. In short, the 77 year old house faces south, there was little of no protection for the entry door for a time, and nails in a brass kick plate caused checks to form. There are also areas where in the joint or the checked area the board has curled upward.
Pretty sure I know what to do. Clean out the checks sand down the raised areas, use a shellac & sawdust mix to fill, and re-finish the outside of the door with a stain & marine varnish. The question is time... In paticular... How much my time is worth.
I don't want to screw my friend over, but I don't want to screw myself either. For years I've heard "You don't charge enough!" in regards to what I built in the past. I know a square door 34" wide with a window is $1200.00 to $1500.00. Add a arched window and it goes up a bit more. To refinishing this door & the hardware, I'm guessing a pro would charge the same amount as to replace it. I don't want to do that.
If there are those out here who do this on the side or even full time, I would like to know what method you use to come up with your hourly rate, or more directly, what you would charge for a project like this. If it helps, there's a link to my website in my signature line. A Private Message or email would work as well. I just need to get a better sence of what to charge and what I'm worth. (BTW: This woodworking thing I do is on the side.)
Thank you for your time.
Tom
Tom
