1 - 16 of 16 Posts
No Longer Here, BY CHOICE
I use epoxy and minerals, etc. not that hard, takes some practice, somewhat of a learning curve as with anything else.
The best I can tell, InLace is just polyester resin with a colored stone mixed in but Im no scientist!
A good call. It is indeed polyester resin, the same used in fibreglass, mixed with different coloured powders or pigments.
The smell of this was the same as when I had to repair a fibreglass boat crack some decades ago. Clue #2 is the MEK hardener.
You can get the colored stone cheaper at WalMart in the pet supplies area - it's for fish tanks.
Whoa! That's true but the hardness of the stones will be variable and likely waaaaay harder than what you'd want to run your chisel over in an inlay.:yes::yes: Matters to me because I fill voids and still turn the piece to get that smooth look and feel---bumpy inlays are not attractive.
Turquoise and malachite themselves aren't all that hard (referring to the hardness#), others won't be as bad in fragment or particulate form for inlays--what you'll run into is color change (dull) as some minerals are ground.
SS user
I'm with Doc re: the workability of Malachite and Turquoise. I have some gorgeous purple stones (I have no idea what they are) that I'd love to use but they are HARD.
The Inlace line offers different colors if Turquoise is not your preference. Again, I don't know what stone (?) they use, but it's workable as well.
Since all of my builds are flat work, sanding is the method I use to flatten the inlay. Even with turquoise, I wouldn't put my blades at risk. I understand that option is not available to turners, though.
1 - 16 of 16 Posts
