Hello,
I just purchased a new Powermatic 14 inch band saw with fence.
I was doing some resawing work with the stock blade, and some basic pine that was maybe 3 inches wide, by 3/4 thick.
After the cut was done, the cut side was very jaggedy. It wasn’t smooth at all.
Is this problem from blade tensioning? Alignment? Bearing guide settings? What would cause this?
How do you achieve the smoothest cut? Is this just how a band saw cuts, and you can always expect to be doing some sanding to remedy this afterwards?
I have attached a picture to show the cut.
Thanks for your reply!
