A few times over the past month my Craftsman bandsaw motor wouldn't start. But a love tap to the motor allowed it to kick on normally. Well it finally stopped starting all together last night, just when I needed to cut some parts, forcing me to have to use one of my lighter-duty bandsaws (which really wasn't up to the task). All it would do is hum when the power was applied.
So I removed the motor and rebuilt it today. I can't be without my band saw. So, since I had to make the repair I figured I put together a real basic tutorial for any one who might be in the same boat and not know what to do about it. Fortunately, I've rebuilt plenty of motors over the years.
Here's the motor I'm dealing with in this case. But this works for MANY motors having capacitor start/centrifugal switches.
Remove the pulley from the shaft by first loosening the set screw with an allen (hex) wrench. Then remove the bracket that the belt guard attaches to.
Next, remove the clips that secure the motor to the mounting frame. You usually do NOT have to completely remove the bolt/nut, like I did. Just loosen it and you'll be able to spread the clips to detach them.
There are four long bolts with nuts that secure the two end caps of the motor. Remove them and pull off the front end cap. Pull the rotor out as well. Make sure to account for the various washers and seals on the shaft that protect the bushings from dust.
At this point I went ahead and vacuumed the dust out of the motor and end cap while working the dust free with a brush. Anytime you open a motor you want to be sure to take time to clean it well enough to remove all particles and old grease/oil.
Make sure to clean the vents and the fan blades well. Clean the grime and oil off of the shaft with alcohol or (acetone) on a rag. Clean the various washers and seals as well (with a dry rag, use alcohol if needed).
If tapping the motor ever makes it start when all it would do is hum otherwise, the problem is likely bad contacts on the switch operated by the centrifugal mechanism.
The centrifugal switch is mounted to the rear end cap. I circled the offending contacts in red.
