1 - 3 of 3 Posts
I have a crack/hole that has formed on my kids slide. Figured I would see if anyone on here has a good technique to fix it.
It is in a fairly flexible spot on the slide, however it is near the side so for the most part it is not slid directly over, however my fear is that a toe or finger could get caught in it. Right now I put some high strength tape over it, seems to work but would like to do something more permanent.
Kevin
Kevin
A picture would help the readers better understand.
How about fibreglass resin on the slide and a piece of fibreglass + resin underneath.
Banned
The problem with fiberglass is the resins don't typically adhere well to plastics... I'd probably patch it with something like a click-bond style epoxy and then sand it in... you'll probably need a filler material if the hole's much bigger than a quarter inch though.
1 - 3 of 3 Posts
