I have a cabinet that Im restoring and have stripped its existing finish with acetone as I saw the veneer was pretty thin. The veneer itself is in pretty good shape. Will just refinish with danish or teak oil.
Because of the thinness of the veneer, any advice on prep-work before oil finish? I figure the veneer was factory sanded so I was going to just oil it up without sanding. But everywhere I read they say sand before oiling. Does this still hold true if the veneer is in good shape? Also if the overall consensus is to sand, what grit should I start with considering how thin the veneer is?
