I had a redwood fence installed about 3 years ago. It was sealed with a Helmsman clear semi gloss water based spar urethane varnish. I had it reapplied yearly. After some heavier than normal rains this year, I have some greying and peeling/cracking, and also some spots that are darkening.
I have received some quotes to sand and reseal, and they're far too high. I'm curious about doing this job myself. I have no experience with woodwork, so any help is greatly appreciated.
Do I sand and reapply the varnish? What grit sandpaper? How many coats of varnish? Should I switch to the oil based varnish instead of the water based?
learn to love the gray. . . .
redwood is used because it has a lot of natural oils that make it weather-resistant.
that also make any kind of 'coating' a losing proposition. it just does not stick....
I think your biggest mistake was using a urethane on a fence, especially water based. A film finish just isn't going to be durable in that application. If it were me when the weather warms up use a chemical paint and varnish remover and take it off. Then use a deck finishing oil. This is something that is easily re-treated when ever it becomes dry.
If you do decide to use a spar varnish again there are much better spar varnishes than Helmsman. The best is Epifanes. It's available at places that sell boat supplies.
Completely agree. The redwood should have been left natural. I would leave the fence alone. Over time it is "shed" the original finish and look better.
Absolutely. The best paint or varnish or sealant or coating for a new redwood fence is NO paint, varnish or sealant or coating for a new redwood fence. Let it age naturally and keep it off the ground and out of the dirt. It will last a long long time.
