So if I can do this, what 1/2 inch router bits will I need? Looking, searching, figure 1/2 bits? stile,rail;but what about for nice panels? throw the thoughts my way.
I can't say how it might work with a router or router table because I used it on a Shopsmith in the vertical drill press mode like an over head shaper, but the doors looked fine.
Anytime you get into larger profiles it's better to use 1/2" router bits. The shank on a 1/4" bit is easily bent and all it would take is a blow out with a larger profile to bend the bit ruining it. You might also look on ebay for a set.
You can raise panels on the table saw. You really don't get to pick profiles, but it makes a nice arts/crafts style panel. I've done it a couple of times, and still don't like it as much as the router table/profiled bit but it's fairly easy to do and you don't invest in expensive bits.
I bought the Freud set and they're great. The instructions were fantastic so the sizes of your door, styles, rails and panels are all in a formula. One thing not mentioned thus far is your router needs to be a good one with muscles and it also needs to be multi speed because you need to slow down the router with the big panel bits.
I've been running a freud set. As stated before the router needs to be in a table with a fence and must be atleast hp. Most manufactures recommend variable speed so you can drop it down too around 7-10k rpm. Your gonna have to make multiple passes. A lift of some sort will make your life alot easier.
1 - 11 of 11 Posts
A forum community dedicated to professional woodworkers and enthusiasts. Come join the discussion about shop safety, wood, carpentry, lumber, finishing, tools, machinery, woodworking related topics, styles, scales, reviews, accessories, classifieds, and more!
