I'm looking to get a clean rabbet cut on the top of a 4x4 to accept a crossing 2x4. I have circular saw, miter saw and jig saw that I can use. Does anyone have any tricks to make sure all the cuts will be flush and perpendicular?
Thanks,
John
In History is the Future
It sounds like you want a half lap joint or lap joint rather than a rabbit or rebate.
Set the circ saw to the correct depth, use a speed sqaure as a guide and cut the two outer lines. Next make random passes inside those lines at the same depth an about 1/2" apart. The remaining wood can be removed easily with a few blows of a hammer and cleaned up with a chisel.
This ain't fine furniture building but a fall back on my construction days. The quality of the end result is dependent upon your attention to detail.
Good luck!
We're saying the same thing, Mike. I guess I wasn't clear. Yes, all passes full depth... or "correct depth" :laughing:
Or maybe half of the full depth.:laughing::laughing:
Or, proportionally the depth to accept a secondary member to complete the joint.:laughing::laughing:
Or, maybe the complimentary depth of the joining members.:laughing::laughing:
Thanks,
John
I would make the shoulder cut first, using a speed square or cross cut guide. I would make the top cut next using a circular saw on a sled with support front and rear to prevent tipping and shifting.
. If you have many to make then a sled is definitely in order.
It should clamp to the side and have the proper fence width for the half lap of a 2 x 4, which would be 1 1 /2".
You want a fool proof jig that once it's located you just run the saw against the fence and it comes out square on both sides.
Then you will need to finish the circular saw cut, which will not be deep enough, about 2" or so with a hand saw to get the 3 1/2" depth.
Or you could just use a hand saw to do the whole process....:blink:
I'm thinking more along the lines of:
(2)(the depth of cut) = (3.5" - the desired remaining thickness)(8)(1/4)
:laughing:
