Edit: Project's (finally) finished Radial butcher block table, thanks for the help everyone!
Hi All,
I'm planning to build a round 'butcher block' style dining room table. It will be 5 feet in diameter, and just to make life interesting I plan to join the staves radially instead of the standard parallel assembly you see on counter-tops. I've attached a sketch of the assembly.
The individual pieces will be 1" inch wide, 1 1/4" thick, and range from 30" in length to 10" at the edge.
My main concern is wood movement potentially cracking the joints. I will probably drill a 1" hole in the center to allow the table to expand and contract with the seasons, but I am not sure if that will be enough to prevent splitting long-term.
I've toyed with the idea of drilling pin-holes where the shorter staves slot between the longer ones to allow further 'room to breath' but would like to avoid drilling more holes in the tabletop if possible.
What do you guys think? Is there a way to manage the wood movement in this type of project or is it doomed to split?
Best,
Hi All,
Best,
