I have a Bosch 1617EV Router motor in Bosch Plunge Router. I want to use a 5/32 drill on it, but the collet is too big. Do they make collets this small?
Regards,
Larry
crosseyed & dyslexic
No. Maybe you should use a dremel. But..wait I have to ask.
What in the wide wide world of sports are you doing anyway??
John
As others have mentioned, the smallest collet I have seen are 1/4in dia.
If you need to drill into something, why not just use a cordless drill.
If you need to rout a groove, a drill bit will not work. The typical drill bit does not cut on the side.
If you want to rout a groove, the 5/32in router bit jschaben linked is the way to go. Slow feed rate. The smaller bits are easier to break.
Perpendicular Holes !
I'm a fanatic for accuracy. I can't drill a perpendicular hole to save my life. It always comes out crooked. So I guess my question is answered. Use a 5/32 router bit to drill a hole. I'm only building a work bench table, but I hate doing something almost as good when I can make it perfect.
Thanks for all the responses,
Regards,
Larry
Dremel ?
Making a work bench. I'm an structural design engineer. I can't help myself. It's got to be dead on.
I hardly use a Dremel except for very delicate grinding or cutting. Not much power for going through 2x4s.
Regards,
Larry
