Hey folks,
I'm putting together my dust collection system using 6" 3034 pvc and now have my first run between my shop and the adjacent room where the DC will be set, but I've run into a problem.
When I go to attach the first 45 I am finding that I am not able to get it connected to the straight run. The 45 has a rubber gasket (see pic below) and no matter what force I use I cant get it fully on the straight pipe, it just seems like the straight pipe is a bit too big.
I should clarify that I am attempting to connect the 45 to an end of a straight run that I cut with the jigsaw, not a bell end. I tried putting some pipe lubricant on the end but it doesnt seem to want to get on there.
All pipe and fittings came from the same vendor.
I tried some other fittings like a coupler and in each case it seems like the addition of the rubber gasket makes the fitting too big to fit on the end of the pipe. I'm wondering if I shouldn't be taking the gasket off and screwing each connection together with sheet metal screws and foil tape, but I wanted to check here before I started removing the gaskets. Or is there something else I am missing?
One other unrelated question: Folks here have strongly recommended going with 6" as much as possible throughout the system. I am planning on ordering this 2HP Grizzly, non cyclone:
http://www.grizzly.com/products/2HP...h-Aluminum-Impeller-Polar-Bear-Series/G0548ZP
and this seperator:
http://www.grizzly.com/products/30-Gallon-Dust-Collection-2-Stage-Cyclone-Separator/W1049
I noticed that the seperator accepts 4" hose. I assume that means that the pipe from the seperator to the dust collector will be 4". Wont that negate the benefit of using 6" pipe to begin with since on a critical connection at the end of the run I am using 4" or is it just a small part of the system and I will still be getting the benefit of the 6" runs so I shouldnt worry about it?
Thanks.
Nathan
and this seperator:
Thanks.
Nathan
