I have a Delta 14" bandsaw that I just installed a 3/8" wide all purpose blade. If I adjust the blade with the indicator on 3/8" there's very little tension. Right now I have it set with the indicator past 3/4" and the blade tracks in the center of the wheel.
It seems to cut okay. I'm not sure how much tension I should apply. I can move the blade fairly easily by grasping the blade by the back blade guard and applying a little pressure.
Thanks for any suggestions..
