Looking at my fishtank I decided that my 54L tank was not nearly large enough, so I jumped online and found a cheap way of expanding, building a plywood box, adding a window on the front and bobs your uncle.
This method is usually used for LARGE tanks however I decided to build a 1200mm long x 400mm high x 350mm deep netting (pun intended) me a nice 168L, using finger joints to connect the panels, I am new to woodworking, loving the new hobby and thought I would share my project, I lost my original drawings so I drew some up quickly using paint, I have started making my joints but doing them manually is taking a while
I have fitted a few finished panels together to check the fit and took a few photo's.
This last photo requires a bit of imagination, this is the right hand side panel joined to the base and part of the 'window frame'. This being the first time I have made and attempt at joinery my fingers are of pretty average quality although i am doing far better then I thought I would be
