I similarly had a bunch of oak and pine molding that I originally asked the same question about. The answers were varied...but now that I have done it I have no regrets. Short of hitting 1 nail which had me spinning a couple of my JET spherical's blades.
I did not even seem to witness much of any dulling. I was generally putting through 2.5" boards and on quick calculation probably close to 500 ft. of them. One suggestion was to use the whole feed so I did continually go from one end to the other in feeding.
Taking off at least 1/32" was also suggested so I was actually cutting below the poly. For me the time savings certainly would have covered the price of a set of new blades...if I needed to. I didn't. Hitting the nail I also was inside looking and discovered there was very little crap build up on the blades at all. Over and above that I would give your rollers and maybe blades a cleaning before starting and give your input/output trays a good waxing...and then have at it....you will be fine.
I should add that along with the people who said it was a bad idea...was my planer manual.
