I'm working on an off-brand 15" planer, and now I've discovered that one of the bed rollers is bent. The first photo is of a softwood board that shows several crossways marks (from blades, I assume) spaced almost 4" apart. I wondered what caused those and discovered the bent roller.
Where does one go to order a replacement roller? The dimensions of the roller are 3 cm in diameter and 34 cm long. (see 2nd photo) Again, this would likely be easy if this were a supported tool, but...
Thanks you guys!
Chuck Barnett
Thanks you guys!
Chuck Barnett
