I just posted in the New Members section and tried to explain that, while Ive always done rough work, I havent done very much fine detail work. So, I recently started my first project, a chess board table.
First of course is the chess board. I had some apple and maple woods, split along time ago from trees that were taken down and have been sitting it the garage for 20 years. I know the dark color is usually a walnut or mahogany but the amber of the apple is certainly enough contrast.
I cut my strips of each, 12" long, 2.25 wide, 3/8 thick. I know the 12" isnt long enough to provide all the spaces but I cut 6 strips of each color.
So a number of concerns. My plan was simply to glue the 3/8 chessboard onto a a piece of 3/4 plywood or mdf and that would be the table top. But then I started surfing the net and read horror story after horror story from people that made chess boards and they warped terribly. And not just chess boards, everything.
It completely paralyzed me. Im now convinced that whatever I make, be it a chess board or a picture frame, Im going to bring it inside and wake up the next morning with a warped, cupped, twisted mess.
Do I need to do anything special to guard against this? Is it a legit concern if using old dried wood? I do work in the garage which tends to be more humid than my house, I suppose (at least in the summer), to the extant that matters.
A little more detail, the strips I cut are about 3/8. The maple is all actually 1/2 the apple is 3/8. And without a thickness planer not sure how I could get them all the same except to glue them flush and then run them on the jointer or use a hand plane.
My original plan was to not worry about it too much. Just glue them flush and then epoxy the "bad" side to the plywood which would fill the gaps. Or would it matter if there were gaps under the pieces that are 3/8?
In any case, that is when I started surfing and came across all the warping horror stories.
Any thoughts from the more experienced?
