Hello all.
I'm making a flag display box for my grandfather who recently passed away at the ripe age of 97. He served in the Navy during WWII. So, this build means a lot to me and is very timely over this Memorial Day weekend (ain't just about bbqs and whatnot).
I'm pretty much following Tommy MacDonald's flag box build that he did for Rough Cut. Part of the build is clamping the sides after mitering them. He achieve the clamp on the 22.5 + 22.5 degree joint by gluing the cutoffs from the sides to the outside of the sides, giving you two parallel surfaces for gluing. Then, you saw off the cauls and plane flat.
The front page of Pop Woodworking has a turning tip for turning half columns. That is to glue up to pieces of wood with paper bag sandwiched between them and use that glue line as the center mark of your turning. When the column is turned, you can easily split the column down the centerline.
Is this a valid strategy to make the caul removal easier for my flag box? Or should I not try this. I would hate to have to scrap my work due to a screw up either way.
Thank you all for making it through a long post and for any thoughts on this you might have.
