That looks great. How old is you daughter
The finish is one coat primer, three thin coats of General Finishes Milk Paint, followed by three coats of General Finishes Satin PolyAcrylic Water Base Top Coat. I sanded between coats with 320 sandpaper (220 after the primer coat). I used a foam brush for the application. I also painted some of the components separately for easier application. I completely finished the plywood backer before attaching (taping of the areas that did not need paint). For the molding of the panels, I coated with two coats of paint before cutting and attaching.Nice work, well done indeed. How did you finish it?
I am assuming that you started with a full size backer of plywood and added the frames to that to make it appear as raised panels...right?
That's a great way to build it and saves lots of groove makin' and tongues on the separate panels. Nice Work! :thumbsup:
How did you conceal the edge of the plywood on the ends, just a full length cap? and if so was it a simple butt joint or mitered?
Any build in progress photos?
She is 13....I think I have mentioned her age in another thread.I was not trying no be nosey. I would have been surprised if it was for a preteen. Looks more for college or late teen.
I appreciate you posting build pictures. This is nearly the style of bed I had in mind for a spare bedroom. You did such a great job and the finish is amazing.I added some build pictures to the album:
http://www.woodworkingtalk.com/members/cps-42222/albums/painted-faux-panel-bed/
