My old 6 in pneumatic sander needs replaced, I want electric with dust collection. 5 inch is OK, but what is with this velcro hook and loop sanding disk option? Aren't they expensive? Please suggest a brand and model for home shop use, any price.
If you decide to buy the DeWalt ROS, here’s a thought. To use up your existing non-hook/loop 6" pads, why not consider the 5" adaptor that I referred to earlier, providing it will adapt to the ROS model.
Make a circle/cut template from 3/8 or 1/2" stock. Cut a 5" square to start with, and make an “X” by drawing a line, corner to corner, to locate the center (you know the process). Drill a small hole in the center. Countersink the hole bottom, to accept a screw for a small lift knob. Then, cut out the circular disc template with a bandsaw. Attach a small knob handle to the center with a screw, and drill a small hole at the edge of the template for desired wall-hanging. You can use a thinner stock, but 3/8" minimum gives you extra thickness for the knob-handle screw’s countersink.
To use the template: With a cutting mat below, place the template over the face of disc (backing still attached). Centering isn’t important because you will have enough scrap excess, after trimming. With slight downward pressure applied, use a sharp utility knife to away the excess paper on the outside of the template. Results is a 5" ready-to-use sanding disc.
Sounds like a lot of work, but it may help to use your huge supply of unused sanding discs. I’d cut some up on days that you are waiting for finish drying-times – and store them until needed.
Sure hope this helps!
- Bob
