My old 6 in pneumatic sander needs replaced, I want electric with dust collection. 5 inch is OK, but what is with this velcro hook and loop sanding disk option? Aren't they expensive? Please suggest a brand and model for home shop use, any price.
That sounds like an orbital sander, not ROS?I have Dewalt ROS that I've used on all my projects and am pretty happy with. It has 2 metal wire clamps and rubber pad to clamp the paper in place. I prefer it over the Velcro that inevitably seems to lose its grip as it gets worn and fills up with grit.
Yes, you are right. Thank you for the correction.That sounds like an orbital sander, not ROS?
Take Half Fast Eddie's suggestion on buying a pad.Thanks for all the quick informational responses. I am a retired hobbiest, keeping occupied at my own easy pace. I will proceed with purchasing the Dewalt. I have built up a boatload of self adhesive 6 inch, no hole, sandpaper over the years. I have several hundred disks that wont suit the new Dewalt.😕
Most of the sanders are decent, Dewalt, Bosch. I use a Makita. What made a big difference for me years ago was switching from sandpaper to Mirka Abranet. Lasts long, consistent grit, no worries of contamination from some sandpapers. I still use sandpaper for hand and block sanding. The Abranet is not cheap, but will last you far longer than any paper will.My old 6 in pneumatic sander needs replaced, I want electric with dust collection. 5 inch is OK, but what is with this velcro hook and loop sanding disk option? Aren't they expensive? Please suggest a brand and model for home shop use, any price.
Well i was not able to find a replacement pad that is 6 inches.Pick … one of the advantages to hook & loop paper is that you can easily pull one off to change grits, and the old one can go back on.
I think you can buy an adhesive pad for that sander, so you can use up all your existing discs.
