1 - 20 of 23 Posts
Our 12 year old upright freezer has decided it would rather not be cold any more.
Has any one converted one to use for drying bowl blanks. What would be needed to control humidity, mold etc?
Any tips or ideas?
Second I will most likely replace it so keeping it in my shop and adding the new one takes up valuable real-estate. How would a freezer survive outside long term if I moved it out back under ( or mostly under) the eaves?
Converting it to drying is no big deal. Several ways to do it from simple to way too much. It should be fine as long as you don't leave it completely exposed. Maybe tarp it?
You need to add a heat source (light bulb) and vents top and bottom. A small fan would be a good idea. Since it has grills for shelves, I'm guessing, that is done. I would add a thermometer just to see how it is doing inside without opening it up.
Let us know how it comes out.
If you put it outside, please put a sturdy hasp and padlock on the door so that kids can't get into it. There have been instances of kids hiding in old fridges/freezers and being trapped inside with fatal consequences.
Part of me says it's chlorine in the gene pool, but it would still be very upsetting to have it happen.
HI as ghost 5 says but add a hole in bottom for condensation to leak out and the bulb to be incandescent 60-100 watt. Round vents 2.5"" diameter as used on cupboards 2 on bottom of door and 2 top of door and fan from computer Regards Roger
The freezer should already have a fan to circulate the air. Since the freezer is broken, you may want to pull the wires for the fan and hook up a manual switch since it will presently be in the thermostat circuit.
Yes a hasp and a hole in the bottom. I was typing fast and forgot those. Should be an easy and inexpensive build. I am thinking of taking some scrap I have and making a drying cabinet since I bought a bowl gouge I guess I need a place to put bowls now :huh:
You only need to consider building a drying cabinet if you want to speed up drying the rough turned bowls. They will likely dry wherever you put them, but may take a few weeks longer.
Yesterday I was at a woodturning show. One demonstrator of natural edge bowls turns his bowls very thin, perhaps 1/8in or less. He said the thin walls dry in a day or two. Since they are natural edge he only turns once and considers any warpage part of the character of the bowl.
Thanks Dave. I plan on doing both but I just need organization, too. Got too much laying around now. If i had a freezer I would be doing this project. Right now I am using the shelf in a closet.
Also I've heard of rigging a thermostat to the light bulb to keep it from getting too warm, surprising how much heat a light bulb can generate.
Turning Wood Into Art
Outside should be fine. As for kids in the freezer - I think it is only the 'old' ones that locked shut that proved to be an issue. The modern style that just close and can be pushed open from the inside I would imagine should be fine. Also I imagine shelves and timber filling it ,pat of the time so little to no room for little ones.
+1 on al, the other advice - I might even look into something like that myself.
Dave The Turning Cowboy
I recently converted an upright freezer to a kiln. I don't know how to post a link to my thread but if you search "kiln" the last post to the thread was 02/02/2013. I did add a vent at the top and a hole at the bottom to let air in. The light bulb is controlled by a thermostat. I have an indoor/outdoor thermometer sending unit in the kiln so I know the temp and humidity. I have pictures posted in the thread. Hope this helps.
Tom
Discussion Starter #13
Tom
Thanks Tom,
That helps
Discussion Starter #14
Yes Dave the fan is in place and still works
Discussion Starter #15
I don't really have to dry them faster but it would be an added bonus having them dry and at the same time keep the stacks more organized and under control.
They can get out, provided that their Freinds haven't locked them in. You really should keep it locked.
1 - 20 of 23 Posts
