First time poster
I've worked w/wood most of my life but have had a unique reaction occur with some old reclaimed wormy chestnut. I hope that someone can give me an explanation, action, and treatment.
I've sanded down the wood and in order to raise the nap I wet a rag with water, applied - w/in the hour, after having let it dry, the wood was covered in black/grey flecks. It looks to be in the grain. I did re-sand and that took most of it out. My question - what is it (mold?), how to treat (I don't want it to happen when I apply my finish), has anyone ever seen before?
I appreciate the feedback
Jack
bzguy
Do you have iron in your water?
Wood reacts this way with iron or rust, clamps that touch water based wood glue always leave black marks.
Just a little from a rag that wiped a rusty surface etc., will stain wood black.
Odd wood, wormy chestnut
Thank you all for the suggestions
- I live in Birmingham and we have very good treated water it's poss that iron still is in the water but I've not ever had this reaction w/any other wood type
- as for the rag having anything on it I use clean rags for any new finishing
So I doubt that I had anything on it
- I use steel wool after I apply my first coat of tung oiL
As it stands I'm sanding it out as much as I can then ill start my finish
Thanks again
J
