1 - 13 of 13 Posts
To attach a swinging door hinge to a door saddle, I need to drill holes into the saddle about 1/2" from the door jamb. My electric drill body gets in the way. Does anyone know of a very narrow drill, with a narrow chuck and a body not much wider? Searched Amazon for "narrow", "thin" and "small" drills, but didn't come up with much. Looking at pictures of right-angle drills, I'm not sure they'd be any better. Have my Dad's old manual "Yankee" drill, which is narrow enough, but I'm not sure I want to work that hard. Any ideas?
John
You can get bellhanger bits as long as 18-24". Try a big box. Aircraft bits get even longer, I suspect the price is in direct relationship to the length though.
Hi!
How about the Fordom flexible shaft? Best in the business, but pricey though. Borrow one maybe?
We believe Dremel makes a much less expensive flex shaft tool, that should do a similar job. Check 'em both out on searches :icon_smile:.
We'd give you links, but our PC is running very poorly as of now :furious:!
Best,
Marena and Vinny
Thanks to all for your replies. I just ordered one of the better-reviewed flex shafts from Amazon. If that doesn't work, I'll try a long bit. Never heard them called aircraft bits. Good to know.
If the flex shaft doesn't work for you, and the holes are 1/8" or so, I've used a right angle attachment on my Dremel to turn it into a mini-drill before. Being a Dremel it doesn't really have any torque, but it works well enough for small holes.
1 - 13 of 13 Posts
