1 - 10 of 10 Posts
Although I have many sets of drills including standard twist drills, wood bits, Forstner bits, and more; I am finding that I need some brad point drills. There are many advertised on the internet, but there is no way to judge the quality. I have seen some sets for around $50 but have no idea of the quality. Some name brand sets are around $60 but again, no idea of the quality. Grizzly has a SteelEx brand set for around $30 but again I have no idea of the quality. And my local hardware stores don't have more than just a few sizes. I want a full index so I have all sizes from 1/8" to 3/8" or 1/2".
Anybody have a recommendation for a brand and source for a good quality brad point drill set.
I wouldn't worry so much about brand. A brad point drill is just a different way of sharpening the bit. I just make my own when ever I need one a different size. I've got a bunch of extra drill bits I can re-purpose by sharpening them into a brad point. While you are shopping for a brad point set you might get a small cheap grinder you can put a metal cut off wheel on it keep the bits sharp.
I'd recommend the set from Lee Valley. They are excellent quality and come in an index. Go cheap and you will regret it.
Discussion Starter #5
Hummm. I would be curious what you use to resharpen them. I can sharpen what is commonly referred to as a conical point drill by hand with a bench grinder. I have made special drill points, but it is tedious with a lot of cut and try. I did a custom counter bore bit once by hand and it worked just fine in plastic. But I want some bits that will cut clean without splintering the outer veneer on plywood even when close to an edge.
I can not recall if any of the inexpensive (under $500) drill bit sharpeners can do a brad point. Frankly, to do a proper job of it, I would think it would require a professional style tool and cutter grinder that would run in the many thousand dollars range. I am not a big fan of sharpeners like Drill Doctor which use plastic parts or parts cast from pot metal. There's more accuracy in my fingertips.
Besides, I have too many backlogged projects as it is. I just want to buy a set of drills.
Well this is quite a bit cheaper than $500. On one side of the grinder is a 1/8" wheel and 1/16" wheel on the other I use for brad point bits. I usually sharpen a chain saw blade with the 1/8" wheel.
Discussion Starter #8
Tom, thanks for the Lee Valley tip. I wasn't going to go cheap. I looked at them and they seem quite good. Ordered a set.
Discussion Starter #9
Quite crude. I will have to give it a try sometime.
Later, that is.
1 - 10 of 10 Posts
