1 - 20 of 22 Posts
I'm trying to route a small slot 1/16" wide, 3/4" long, and at least 3/8" deep. I've found 1/16" bits, but the cutters are not long enough to cut 3/8" deep. Anyone have a source for a longer 1/16" bit, or have a different suggestion of how I could make this type of slot? Thanks!
Laughing (at myself too)!
I thought of that but if the cutting depth of the bit is less than 3/8" .....
This is a toughie. I looked around on line and the longest 16th diameter bit I found was only 5/16".
I've never heard of a 1/16"kerf TS blade so that idea is a non-starter.
Maybe a glue up using a well waxed 1/16" spacer but then the thing would have to be removed. Eek!
Back to square one.
Without a clear description of the project its hard to suggest alternative methods.
Brainstorming here. Laugh away!
How about a glue up using a well waxed 1/16" thick metal spacer longer than the workpiece (edit: and taller than the slot).
After the glue sets heat the metal to liquefy the wax the pull the spacer out of the slot.
Or maybe I just need yo get to sleep?
A router bit that skinny would likely just snap off. You might be able to use a drill bit like this. It probably could not be mounted in a router collet, but maybe you could rig up a simple jig to use in a drill.
Thanks for the feedback everyone. I figured strength of the bit was why they don't seem to come longer than 5/16 in that thin of a cutter. The application I'm using it for is a little peculiar-- to make a slot that will snugly hold a penny buried half way in to the wood. I was hoping there might be an obscure or specialized tool maker that had a longer bit in a special metal material. Guess the search continues...
A drill bit can cut with its edges. Or, you could use a flat blade wood carving tool. There are many with thickness less than 1/16", and thicknesses varied on up, and different widths. A few taps into the wood you can make a nice clean tight slot.
What is the overall shape of the part you want the penny slot in? There are 1/16" thick slot cutters available, generally used for t-shaped edging. Another option would be to split the piece right where you want the slot, then face route 1/16" deep on one side. Then glue the part back together. Just be careful not get any glue in the slot.
I had considered a slot cutter, but would really like to isolate the length of the slot to the diameter of the penny (3/4in). The idea to face route before I glue the laminations could work though. I would have to change the orientation of the lamination, but it might work. Or I guess I could use the slot cutter idea and slot the adjoining laminated faces before glue up. Some stuff to think about.
A 1/16 drill bit on a drill press wood do it. You lay out the portion you want to mortise on your material (1/16x3/4x3/8). Then make several drill holes as close together as possible. Then you will be able to clean it up with a utility knife (make sure it's sharp) or a small chisel blade putty knife. That should take care of it.
Discussion Starter · #15 ·
By the way, I'm a product designer by trade, and they've been talking about "crowd sourced" design like it's a new trend, but you guys and the communities around these forums are the originators of leveraging the Internet for "crowd sourced" designs. Thanks again, and keep it up!
Eek!!!! $$$$$$
I got a little dizzy but I caught myself before I fell down.
Cool technology but it's not a purchase I can justify for my small shop.
All the described benefits seem to be applicable to large production operations.
Thanx fer ferthring mi ejumikashun.
Eek!!!! $$$$$$
Glad to read that you managed to avoid injury. :laughing:
1 - 20 of 22 Posts
