I recently purchased a Delta Rockwell Planer 22-401. It was working great until the belt that drives the cutterhead broke. It is part 22-424, Cutterhead Drive Belt, 7M Polyflex. 66.9 inches OC. The belt is 0.26 inches wide at the top, and 0.08 inches at the bottom where it meets the pulley, And has a height of about 0.19 inches.
I can't find the part online. Any thoughts?
I can find 70" v-belts, so I am thinking of replacing the pulleys with 1/2 inch pulleys.
One posible source might be here:
Thanks for the suggestion. Gates says the correct replacement is
SKU: 7M1700
Gates 7M1700 Polyflex Light Duty V-Belt 8903-1700
However, Gates is at least 3 months behind in resupply to its distributors.
· where's my table saw?
edited removed
SKU: 7M1700
I think you can order direct from Gates. I think I've done that in the distant past. Either that or it was a Gates belt that I order through another supplier.
Did you read the post above?
