I have an older 5hp 120VAC SpeedAir compressor which has been giving me some problems lately. The unit will come up to pressure fine but frequently when the compressor shuts off, the pressure bleed that I believe is supposed to releave the pressure in the compressor itself, continues to leak down at a high rate, draining the tank. If I don't shut off the control switch, when it reaches the low pressure to cycle and attempts to start up, it can't and blows the breaker.
I've replaced the pressure switch which seemed to help at first but now the problem had gotten even worse. Instead of the bleed valve getting stuck open occasionally, it now gets stuck nearly every time. Did I simply get a bad switch or is there another componet involved that I need to look at?
Thanks,
Jeff
Thanks,
Jeff
