1 - 14 of 14 Posts
Hello all! I asked a question here a few weeks ago and received excellent advise. The granddaughter is riding her Toddler Town Car all over the house. Score one for Pawpaw! I don't know how many posts I must make to qualify me to add photos. Thanks to Cabinetman and the others who answered my questions.
Now, for my current question. I'm a rank beginner working at building a Roubo bench per Chris Schwarz's WORKBENCHES book. I'll be ready to assemble the base as soon as I get the mortises done. Schwarz recommends using white oak pegs for drawboring the legs. Pegs for the stretchers will be 3/8" x 3-3/4" long. The pegs for the top will be 3/8" x 6". I do not have any white oak. I do have red oak, ash, ambrosia maple, and more mesquite than I can ever use. Would any of these be a reasonable substitute? If not, from whom might I order a small amount of white oak? I'm a 2 hr, 75 mph drive from a supplier.
Thanks for any and all assistance.
Discussion Starter #4
Thank you! I will make dowels from the red oak and the ash, then compare to see which I like better with the SYP top & legs.
Any particular reason I shouldn't use mesquite?
Discussion Starter #6
Pardon my asking. I thought this might be a learning opportunity regarding different characteristics and properties of these woods relative to the intended use.
As long as it is lumber and not smoking wood mesquite would work fine. Wood takes a really long time to air dry where kiln dried lumber is more stable.
Discussion Starter #10
for the good info.
Hammer1, I have the Lie-Nielsen dowel plate. I'll do as you recommend and split the wood first.
Another question: I need to make a 5/8" wide by 1-1/2" deep by 56" long slot in the bench top. Can this be done with a smaller diameter spiral upcut bit in a plunge router? I couldn't find a 5/8" with a 1/2" shank.
Yes. I used a 1/2 x 2 1/2 straight bit and an edge guide. You just have to make a couple of passes for the width, and several passes to get to the proper depth.
Discussion Starter #12
CPS, I appreciate that info. Did you build a Roubo? If so, any tips or tricks you could pass on?
1 - 14 of 14 Posts
