Hello all,
I'm new to this forum and to woodworking in general. I'm starting my first woodburning project (attempting to do a fathers day gift) using a 3/4" piece of untreated pine framing lumber. I would like to round out the corners on the piece and need some advice on the best tool for the job. The only tools I currently have in my arsenal are some wood chisels and a crosscut saw (I know this won't work). I have seen some youtube videos where people have used chisels to do the rounding and then finished it off with sanding but that seems to take a fair bit of time.
Besides the chisels I came across videos for three other tools. 1. A fret saw for very fine work and but I read this is only good for softwood less than 2" thick which mine is however I would appreciate if someone can confirm this is true. 2. A coping saw which supposedly isn't as good for really fine work but is good for thicker hardwoods as well as softwoods and is better for a broader range of tasks. 3. A scroll saw but this seems like it might be overkill for this project (not to mention expensive to buy). Having said that I found someone selling one for $40 on Kijiji which is within my price point if the consensus is the scroll is the best/easiest tool for this job. I don't mind putting some elbow grease into it so have no trouble using a fret or coping saw if one of these is the better tool to use.
I would also like advice on how best to not only round out the square corners but how to bevel the edges if possible. This isn't a "must have" but a "nice to have" if it's not too complicated.
I have attached a pic of the piece I'm using. I don't know if you can see the pencil marks for the corners but there isn't much I have to take off which is why I'm a bit concerned about using a chisel for such a small area on each corner. I'm afraid I might split the wood. There's maybe only a 1/2" to come of on each corner.
Thanks in advance for suggestions and advice.
Cheers.
Karen
Cheers.
Karen
