These are my abrasive rools..
SM-J700F cihazımdan Tapatalk kullanılarak gönderildi
Tool Agnostic,,,,,,,,,,,,,,,,,,,,,,,,,,,,, I considered a design similar to the one you suggested above.
The problems with the long pole holder are:
- Changing one roll is a hassle, because you must organize all the rolls.
Good points. Thank you.Tool Agnostic, While your statement is correct, in the design suggested above, changing one roll has no effect to any other roll. Each roll hangs on it own dowel rod. The rolls of paper AND the individual dowels rods are separated by the plywood supports between each roll. The notch for the dowels is cut in from each side and NOT all the way thru the supports.
I tested it with with white mdf yesterday john .. it looks not bad.. i guess i will make it with mdf..Faith - can you gather up some scrap materials to test your projects with?
here at the Home Centers, there are inexpensive plastics just for white marking boards.
you would have to do your own tests on boards that you paint yourself.
