Jack of too many trades..
Hello All, first post. I've been reading your forums for a few days now. From what I've seen, this seems like an excellent discussion forum for folks with a range of skills and tool-sets.
I am a (more-than-novice, but still) amateur wood-worker. My projects are usually related to home restoration/repair and the occasional furniture project. I've got windows on my current agenda.
I've never had a whole lot of money for expensive tools, but this gives me an excellent appreciation for quality and features, when I finally do have the cash to upgrade.
That said... I've got a Benchtop Mortising Machine... and it came from Harbor Freight. :blink: In my price range, there did not appear to be much increase in quality or features if I went with a Delta. Grizzly just significantly raised their prices, so here I am...
Anyway, the motor, frame, chuck, plunge mechanism are all quite solid and tight. I think should last through my new few projects. However, the fence and hold-down are absolutely awful. They actually interfere with the mortising bit. I've added a supplementary wooden fence, but it seems like there should be some better options.
Does anyone have any suggestions for a fence/hold-down upgrade? I'm not experienced enough with power mortising to know what features can and should be added.
Thanks for any suggestions
This won't help a bit but I replaced my harbor fight mortiser with a delta and that got rid of all the problems with it:yes:.
I wish I could afford that sort of solution (replacement). Unfortunately, the next step in quality is about twice as much as I paid for this thing and this was really all that I could afford.
I'm fairly sure that the hold-down is not going to survive. The aluminum "L" bracket-thing that holds the fence and the hold-down is under a lot of stress each time the mortising bit sticks in my workpiece.
I think a custom jig of some sort might helpful, but I was hoping for some sort of after-market device, not unlike the high-quality replacement fences for tablesaws.
Sawdust Creator
I think the problem, is that as you withdraw the bit the wood rotates a bit making it hard to withdraw. I have a few ideas and hope to try them out soon on mine utilizing extruded aluminum and some toggle clamps.
If the bit sticking is the problem that may need some sticking prevention modification. I'm thinking about 10 minutes of draw filing would do it.
I read something about filing the bit to improve performance. Do I need to file the inside of the bit with a needle file, or just hone the exterior with a standard flat file?
It's gotten a little easier to use, since I realized that the "exhaust" part of the mortising bit needs to be turned "out" (when possible).
I also switch to using one of my higher quality vintage CMT bits rather than the the cheapo bits that came with the machine. Unfortunately, sticking is still a problem.
I've actually reached the end of my first two "test" sashes. The mortiser won't be needed until I am ready to build my next pair of sashes.
I've got a couple ideas on upgrades, but best bet would seem to be removing the original hold-down and MDF plate altogether and secure something directly to tapped screw holes in the foot of the tool.
Ryan, please post a pic if you get something worked out.
You need to sharpen the inside of the chisel. If you sharpen the outside you will alter the dimension of the mortise. I have seen some sharpeners specifically for this. They look like a cone that you spin in the mouth of the chisel. I think Rockler has them, but I'm sure toucan find them elsewhere.
