Ok, I figured I'd run this buy everyone as I am sure you had to deal with this at some time. Made my daughter in law a giraffe cutout of plywood which needed painted to be finished to use as a height measure gauge on the wall. Due to her not getting around to painting it for almost 2 years ( yes, 2 years! :) ), it has some surface mold on it from being in the garage. I am thinking of using straight Clorox on the parts to kill the mold before painting so it doesn't come thru. Any thoughts on this other than I'll have to probably lightly sand the raised wood some, planning on using a damp rag as to not do too much damage?
Chlorox will work, as will a very dilute solution of bleach, which is basically what chlorox contains.
As soon as the bleach contacts the mold it will die, so you can use a light spray of the chlorox.
The water will likely raise the grain, so let it dry and then a light sanding to get back to smooth.
If the item is being painted the paint will also kill the mold due to no air, but the dark stain could show through, but best to remove first.
In addition to the spritz of Clorox, I would suggest you pick up a spray can of Zinseer BIN primer. It will do the best job of hiding-and keeping hidden-the mold marks. It provided an excellent base for the application of additional finishes.
