1 - 14 of 14 Posts
"To slide...or not to slide?"...that is the question!
If you have a table saw (with eventual cross cut sled) does it make sense to spend the extra money on a sliding miter saw?
If not...with coupons and membership points I could get this for $61 +tax...thoughts?
http://www.sears.com/craftsman-10in...p-00921236000P?prdNo=2&blockNo=2&blockType=G2
Yes, it does make sense. Much easier to walk over to the sliding compound miter saw(scms) that get out the sled for the table saw.
No Longer Here, BY CHOICE
It depends. You doing rough cuts or are you expecting precise miters? I can cut near perfect miters with my CMS but If I was doing boxes or frames or something that required perfect miters, I would definately opt for the TS and a cross cut sled. A sled changes the whole ball game. I built a super sled and I love it. Of course now Ill be modifying it to work on my new old TS. You should also take into account there is a bit of deflection with a slider. I love my miter saw for quick rough cuts but would never trust it for precise finish cuts. The saw you linked is similar to the one I have. Ive had it for years and its still going strong.
Sawdust Creator
I don't know that I'd buy a 10 inch non slider.....its only going to cut like 6 inches wide or so.....I'd at a minimum buy a 12 inch non slider...
http://www.sears.com/craftsman-10inch-compound-miter-saw-21236/p-00921236000P?prdNo=2&blockNo=2&blockType=G2
i'd seriously look at the ridgid 10" slider. with a 20% off harbor freight coupon, that saw could be gotten for $320. qualifies for ridgid's LSA.
Or you could go with the Harbor Freight 12" Dual Bevel Sliding Compound Miter Saw.
There's a coupon out there to get it for $129.95
I guess it all really depends on what you are going to be doing with it. If you think you are going to make precise cuts with a scms you are sadly mistaken. But if you are just going to rough cut stock then I'd say go ahead with it. I don't use a slider anymore but my next saw will be a Omga RAS :) Which will be faster and safer than a cross cut sled also more accurate for larger panels.
Discussion Starter · #12 ·
Do you happen to have one? Like everyone else on the forum I have heard a lot of mixed reviews on the HF power tools.
I decided to go with a slide and have been looking at either at the 10" Craftsman ($200) or the 10" Kobalt from Lowes ($180). Both slide and have single bevel.
I just wasted 2 hours researching sliders last night, I see people complaining about the same poor quality issues on all the saws I experienced 5 years ago when I last owned a miter saw. If I'm building a deck okay fine, but for fine woodworking nope.
Then you might be interested in this . . .
1 - 14 of 14 Posts
