I need some advice on staining a mahogany door that I will be installing in my house. It's an exterior door that faces West, however it never gets any direct sunlight due to some large pine trees. I have experimented with a couple of Minwax Stains and was fairly happy with the dark mahogany or espresso colors. I was all set to use it before a friend of mine warned me that it was only intended to be used on Interiors. I was curious if anybody had any thoughts on this and could give me more information or advice on what to do since I am dead set on achieving this dark brown finish on my exterior door and trim. It's really confusing trying to find a stain that will work and it makes me wonder how they did it a hundred years ago. I was also looking at their duraseal line of stains that were designed for hardwood floors. I have successfully used it on my staircase and railing and it looks great. Not sure why that can't be used on an exterior with the proper top coating either.
Also, if anybody has any suggestions on a top coat that won't peel or crack that would be helpful, as well. My friend warned me to stay away from Helsmann Spar and told me that I need to find something that will Flex with the movement of the wood. But unfortunately he couldn't give me any further advice. I don't want to go with a full gloss that you would normally find in a marine store. I'm looking for a finish between satin and semi-gloss. Thanks for your knowledge and advice ahead of time!
