I am making a shelf for a friend out of MDF. From experience I know the edges are a bit rough even after painting and I just want to finish it better. Has anyone found any type of edge banding appropriate for MDF?
You could use a high pressure laminate (Formica), applied with contact cement. Or, you could use one of many types of wood/PVC iron on edging (preglued). Or, you could use solid wood.I am making a shelf for a friend out of MDF. From experience I know the edges are a bit rough even after painting and I just want to finish it better. Has anyone found any type of edge banding appropriate for MDF?
By the way, MDF is probably the worst material for shelves if they span more than a foot or so. Only plastic is worse in my experience. Plywood would be better, but almost any solid wood would be the best.
+1 works great!I used sheetrock mud on the shelf I built out of mdf worked really well. Press into edges good then after its dry sand a little and paint.
