Never heard of turpentine in that blend. What are those older sources, please?
Never heard of turpentine in that blend. What are those older sources, please?Looking through some older source and it seems a popular finish is a blend of beeswax, mineral spirits and turpentine.
tried bees wax and turps not impresed had luck with wax and linseed oilLooking through some older source and it seems a popular finish is a blend of beeswax, mineral spirits and turpentine.
if you're using turpentine in your home-made wax finishing, what brands are you using? It seems like most commercially available brands are no longer 100% pure gum turpentine, more like 30% (even if the label says "pure gum turpentine"). Does this impact the quality of the finish?
Interesting… How did you mix the wax and Lindseed oil?tried bees wax and turps not impresed had luck with wax and linseed oil
place a large chunk of wax in a tin half fill with linseed and heat same till mixed pour in jar and keepInteresting… How did you mix the wax and Lindseed oil?
