1 - 20 of 27 Posts
Hey guys, i'm a new guy around here. I'm looking to buy a miter saw. I was considering a Makita or Dewalt 10" and then noticed a Performax 10" slider at Menards. i fully realize you guys have higher standards than a saw from Menards, but here's my thought. The saw is on sale a lot for around $170- about the same as a Makita or Dewalt non-slider. I want something extremely accurate and looking it over- everything would be adjustable if the factory didn't get it just right. Additionally, no matter what saw i get, i'd be aiming for a really nice Frued or Forrest Chopmaster blade. This is for hobby and home use- not my job, so though i want it to be a good saw, a $500 is not an option.
Thoughts?
thanks,
jeff
I'd save up and buy the Makita. If you just can't justify the expense, then I'd examine whether or not you really need a slider. I've messed with those saws at Menards, and I don't think they could be relied upon to make the same cut over and over.
Woodworker and Contractor
Put the saw blade down like you just cut a peice of wood then put a little pressure left then right if it flexs too much you will have a hard time being accurate. They all flex some but the heap ones take very little force an move when you cut the nice one you have to force to flex. This is the most important thing to me. Also a chop saw is only good for small >6" stuff usally where a slider will cut about 13" so decide what you need.
PS For a slider pull the blade all the way to you for the flex test
Excellent advise guys. Based on the "flex" test here are my findings:
Dewalt, Makita, and Bosch are flawless- hardly no movement whatsoever. lets say 10/10
at a level of 8/10 are Hitachi and (pleasant surprise) the Performax 10" slider.
at 5/10 was the Performax 10" non slider- weird that it was worse than the slider.
at 3/10 was "Tool Shop" brand, Kobalt (Lowes), Skil, and Masterforce.
So, yes, the others are better, but I honestly tried to be unbiased and i'm thinking the Performax slider is at least the best value.
Thanks for the help. Any other suggestions?
What about blade recommendations?
jeff
In making your decision on a saw purchase, compare the vitals like:
Cutting capacities
Amps = power
What are the fixed stops
How do the scales read
Does it bevel in one or two directions
Ease of use - handle/switch design
Accessories that come with it
Weight
Blade changing details
Type/height/length of fence
Permanency of miter scales
Dust collection port
Ability to bolt it down
And the final touch to having good performance is to get the best blade you can afford.
I have a 10" Ridgid and I like it a lot. It isn't a slider but I have never found a need for that feature. Anything I ever needed to do my table saw was more than capible of doing.
Discussion Starter · #10 ·
I've heard good things about Ridgid. my reason for a slider is because i do not have a table saw and would like to do most with the extra capacity of the slider- ie. signs and stuff- like the kind with a clever saying and made to look vintage. My thought is this- a slider to do most, and for the ocasional rip cut, invest in a decent rail system for a circular saw.
how bout thoughts on blades? what are the different hook angles meant to accomplish- -5degree, 0 degree, 5 degree... I see different angles for blades that all claim "crosscut". I intend on getting an 80t blade. Forrest? Freud? any real bargain out there that performs well?
Thanks for all the input guys. I don't have the luxury of spending money just to try stuff...
jeff
Jeff,
If it were me, I'd buy a tablesaw before a mitre saw. You can do a lot more with a tablesaw. Even if you buy a small portable benchtop model I think you'll be better off. If you decide to go with a mitre saw I believe I have heard that a 0 rake or even negative rake angle is best. Can anyone confirm that? Check out the blades from Ridge Carbide. They are the best blades I have ever used.
I have the 10" Ridgid as well. With the exception of some filing to get the miterlock 90 degrees...happy. More convenient than a table saw sled for nipping off the ends of boards. I love my Bosch 4000 though...don't get me wrong. It's the very least acceptable portable TS IMHO. Great saw for my applications.:thumbsup:
Reading from my 2008 Taunton's tool Guide about 10" SLIDING miter saws, I read to you the order of the saws from best to worst:
Bosch 4410L (4.52 rating);
Makita LS1013FL (4.44 r);
Hitachi C10FSH (4.41 r);
Milwaukee 6497-6 (4.30 r)
Chicago Electric 90891-7VGA (3.18 r)
Bosch got the "editors best overall choice" and the "Readers choice" awards.
While Milwaukee got the "Editors best value choice" award.
Steve
jeff
I own the 12-inch Ridgid slider and love it. (I formally reviewed the saw in the product-review section of this web site.) I now have a 72-tooth Freud "Industrial" miter saw blade on it (-5 degree hook angle to minimize lift) and it is considerably better than the blade that came with the saw. (I will save that original Ridgid blade for when I cut pressure treated stuff, or maybe MDF boards.) Of course, the Ridgid slider costs a bundle (on sale at HD for $499 lately; previously $549 and even $595 at one time), but under some conditions it would be worth the cost. Hell, it just feels good having it on hand to look at. Note that it weighs 70 pounds, so it mandates being formally installed on a movable workstand.
Howard Ferstler
Discussion Starter · #17 ·
Thanks for all your replies and input guys. I'm certainly glad you steered me away from the Performax. I checked the local pawn shops, and found a Makita LS1013 for $270 in literally imaculate condition. got it for $250, and couldn't be more please. very solid machine. It has the Mak blade- i think 64t- which will work for a while.
It is missing the two extension rails, the vertical clamp, and also the blade changing wrench. Can these be found anywhere? should i just post a wanted ad? Are there aftermarket accessories that will fit it?
Thanks!
jeff
Makita parts
Contact Makita at www.makita.com. They will put you in contact with a local parts center.
Congrats on the new saw. Great price. Be sure to keep a sharp blade in it. They can 'walk' a bit when the blade gets old.
The Mak-blade is a good one. Mine is a 70 tooth quiet cut, and it is really smooth.
Chop Saws
The bottom line is that no matter what tool you buy, you'll learn it's strengths and weaknesses and as you progress you will learn to "work" more acurately. I've seen a jackass on a beautiful saw and a craftsman on a piece of crap and the results were more of a reflection of who was using the saw and not the saw itself. They all cut! My chop saw is almost 20 years old and It can do what a new one can perhaps a milisecond slower than a new one but a fine job just the same.
Thanks!
jeff
I have had that same saw for 10 years now and your going to love it. It has lots of adjustment places on the saw
1 - 20 of 27 Posts
