1 - 6 of 6 Posts
Hello, guys. I am really in need of your advice. I want to bore 40cm deep in wood. What bit would you recommend to drill so long? Thanks.
What diameter bit, accuracy and what kind of wood is it? There are paddle bits that can easily drill a hole that deep but are not very accurate.
Not so
I wouldn't use a threaded point auger bit with a power source. Those types are designed to work slow with a hand brace. For longer than jobber length, a long drill bit, AKA as a "bellhangers bit" come in lengths that can do what you want. They are probably available in both 135° and 118° points.
The hand brace bits have square tapered shank that fit on a 2 jaw chuck.
The electrician's augers have a 3 side shank which is meant to be inserted in a power drill. I have used this type for years with no issues except you have better hang on 'cause it will drill agressively. I just used a 3/4" bit yesterday for a wiring project. I have about 20 in different sizes and lengths and used them in battery power drills on slow speed and in 1/2 corded drills which run about 500 RPMs. :yes:
A little off-topic, but that looks amazing!
1 - 6 of 6 Posts
