1 - 2 of 2 Posts
This build thread made a while ago started with a live edge. Check it out.
http://www.woodworkingtalk.com/f13/build-thread-whisky-cabinet-45776/
Here's what I did. There are many ways to do it though, and I've only done a live edge once.
I used a cheap chisel to scrape off the bark. I had to wear a respirator as the stuff in the bark drove my allergies wild, just a heads up. Then I used my ROS with 80 grit to get rid of what was left over. Note that I used the existing bark line and sapwood line as a guide. You can do a little re-shaping at this point. Then I hand planed one side "flat enough" to skip plane it in my planer.
Let us know how you do.
Oh, I should also say that some people have good luck using a "flap wheel" to sand down the edge, but the way I did it, I didn't have to buy anything.
1 - 2 of 2 Posts
